Hi! I live in Chile and the ping is… Bad… Like really bad.
Need a vpn to play better… But I dont kno if I can put one in the ps5… I looked at the Internet for info… But there was no good info… So… Is there anyone that knows what vpn works and how to make it work on the ps5
I was always under the impression that if your connection is bad, it is bad, And that a VPN is only there to make services think you are somewhere you are not.
If you suffer from a poor connection to a server, pretending to be from a different area would not fix that because you are still trying to access the same content using the same connection, regardless of where you make the server think you are.
A VPN will send your connection through a different chain of servers. There is some chance this will be better than the current chain of servers. Services like WTF Fast and Ping Zapper try to optimize their networks for games. People have reported mixed results so VPN’s are not a silver bullet. However these services have free trials so its worth experimenting at least.
