Connecting a switch to a VPN can be useful for several reasons. For instance, playing online games over a network with an uncooperative NAT type or playing with (potentially) faster speeds with someone a far distance away. I am sure this information is available elsewhere, but I thought it might be useful to write this guide based on my experience.
Items you will need:
- Nintendo Switch (obviously)
- Windows Computer (I am sure this is possible with Mac or Linux, but I have only tried this on Windows.)
- Ideally Ethernet internet connection for the computer, although a Wi-Fi connection is ok. Please don’t use Wi-Fi for a competitive online game however, as it will likely be pretty laggy.
- Switch OLED dock or USB to Ethernet adapter for switch (look for cheapest switch compatible one)
- USB to Ethernet adapter for the computer (any way to connect the PC to an Ethernet connection will do)
- A VPN that you can run on the computer. Any VPN should work.
Note: if connecting to the internet over Ethernet, your will need 2 ethernet connections. (Probably one USB adapter and one built in to your computer.)
Steps to set it up:
- Connect your computer to the internet and to the VPN.
- Connect your switch to an Ethernet cable and connect that cable to your computer (probably with a USB adapter). Power on your Switch.
- Open Control Panel and go to Network and Internet > Network and Sharing Center
- You should see 3 networks in your active networks. One should be your actual internet connection, one should be your VPN, and one should be an Unidentified Network for your Switch. Open Change adapter settings.
- In the new Network Connections menu, right click the connection for your VPN and select Properties.
- Change to the Sharing tab and check the box for Allow other network users to connect through this computer’s Internet connection. In the drop down, select the connection for the Unidentified Network that is associated with your Switch. Uncheck the box for Allow other network users to control or disable the shared Internet connection. Click Ok.
That’s it! Wait a bit and your switch should show an Ethernet connection to the internet! If you encounter any issues or dropouts, go back to the Properties menu and toggle the first check box off, click OK, then toggle it on and click OK again.
Hope this is helpful to people, it took me a while to figure this out.
