Does GlobalProtect for Android work for anyone on a recent phone? or at least a Samsung Galaxy phone? I can connect to the VPN but I can’t access anything on the other side of it. VPN site works fine in Windows and iPhone versions. Tried different versions as well. I’m running Android 14 on a Samsung Galaxy S22 Ultra.
PS: I vaguely remember a problem with certs not being trusted or the cert store not downloading the certs on the Android. No idea how to manually install the certs from the VPN’s site. And if this is the problem, is it a Samsung problem? Google problem? Palo Alto problem? Cert problem?
You have a GP licence right?
Yes, you need a license and a public certificate to make it works, without it I have problems with iPhone too.
We have Prisma Access with GP on Android - works reasonably well - clashes with MTD solution i.e. Defender for Endpoint and or Lookout for work. You need to turn off one over the other to make it work. But after all those finnagling - it works
I am using Samsung Galaxy Tab A9+ with Android 14. I can connect to GlobalProtect and use RD client for connecting to my remote PC at work running a Win10.
Just confirmed that we do have an active gateway license.
Just confirmed that we do have an active gateway license. So I need to look at the public certificate. Any idea on how to obtain that cert from an android? if i connect to the gateway from Windows (using Chrome/Edge), I can export the cert at the root, intermediate and name levels. I tried multiple browsers in Android and didnt see that option. I realize this isn’t a GP question now but curious how others are distributing those certs to their android users.
did you have to ask your users to download a cert before hand?
yo sorry for contacting you like this but it wont let me dm you probably cuz my acc is new, i saw your post from like 2 years ago for earmuffs or similar that block all sound and im wondering if you ever found solution to the problem? i need something like this myself because im awake at night in a place with noisy days
You have to buy a new certificate for your FQDN (for example I use a cheap one on ssls.com) after register a domain name for it. Then import the certificate and the chain on the firewall and use it for GlobalProtect. The iPhone/Android will check that certificate with their public CA and validate it, without the need to import or load it into the phone.
No, we have pushed the certs via Intune. However GP client t on Android still forces a selection even when there is one cert. But no downloads
