Hi. Can someone help direct me to a fix for this?
While using mobile data, I click on the dblegends icon on my phone and it gets stuck on error message CR990504.
If i switch to wifi and restart the game then it’s playable. Anyone figure out a work around for this?
I want to be able to play this without using wifi.
I have the exact same issue. Works fine on wifi. I contacted Bandai and they gave me an answer to a completely different issue as if they didn’t even read my explanation of the problem.
Try close the app before switching to data. If you dont you get a error that says you are already logged in if that happens you are gonna have to wait a while. Not sure if it is that one
I’m also having the same problem with my 6t, and a VPN doesn’t work. The error code I get is CR990504, with or without the VPN, and this is the only game I play that has this issue.
I upgraded to a 6t from a OnePlus One running CyenogenMod which had no problems using data to connect and play the game. Both phones were on T-Mobile. The CyenogenMod O/S was based on Marshmallow while the 6t is running Oxygen O/S based on Pie. I’m wondering if there is something in the modified O/S or Pie that game servers don’t like.
I sent inquiries to both Bandai and OnePlus to see if they care or might have a fix. If I learn anything, will keep you posted.
