Fastest VPN for IPhone?
I’m basically on a free one nontop because of reddit being blocked and it’s annoyingly slow.
I’m willing to pay for a good vpn if it’s reasonably priced and fast.
On your laptop or pc you only need to change your preferred DNS to 8.8.8.8 (Google) or 1.1.1.1 (Cloudflare). On your phone → just install an app called 1111 . ISPs in Vietnam are only blocking domains, so a DNS solution is enough - no need for a VPN
I use mullvad vpn and its nice
You should consider NordVPN
surfshark, but it really sucks for PC gaming for some reason with my viettel ISP. everything else like browsing, working, netflix, media consumption is all great.
I paid for surfshark and it’s great
If changing dns on your laptop works it should be the same for your phone.
Same, and it also supplies free data
Yes that’s true, 1111 is just a DNS service, not a VPN. You can either use it (which has an extra encryption feature) or change the DNS setting natively
