Hello does anyone use f1tv pro on a firestick specifically using a VPN because I have had problems using VPNS on Firestick can someone tell me the process when using f1 tv pro on a firestick in terms of the vpn and do I need to restart my firestick etc.
I use NordVPN on my Firestick. I set it to a European country (I normally use Greece) then run the F1TV app and everything works no problem.
Try force quitting the F1TV app if you’re having issues, and make sure the VPN is on first.
