Hi guy, we’ve got SSLVPN setup with split tunnelling enabled. We now need our VPN users to access a website that has our office IP whitelisted. We want to see if there is a way split tunnelling could skip a specific website or any way to set the VPN connections to got to the website as office IP?
Many thanks
Assuming typical default SSL VPN setup, the routes installed on the client are defined in the firewall policy. So to route that website over the SSL VPN, create an FQDN address object for the site in question and add it to the destinations on your inbound SSL VPN policy. That should install a route on client directing the associated address for that site over the SSL VPN tunnel, if I recall correctly.
If the website has a fixed ip add it in the sslvpn portal routing address.
The better way would be managing the routing addresses via fw policies. Then you can use also fqdns. Here’s the complete description Technical Tip: Access to Specific FQDN using Split... - Fortinet Community
Thats a kind of situation related question. Did you set the split as SD-WAN or what?
Make sure your firewall can resolve that address as well. Ping it from the CLI by name so you know the FQDN address object will work.
This, when allowing the traffic using firewall policy the route is automatically added next time the user connects using FortiClient
This is the correct way.
The one potential gotcha (though rare) is some very large websites can resolve different ip addresses depending where in the world you look them up in DNS. In a Rare case you may have a client behind split VPN resolve a different IP than your firewall did when it created the route to grab and therefor the traffic won’t pass via the sslvpn.
No, we don’t have it setup…yet
I have and do it myself but because of IP costs and in the SLA config. Are you doing deep packet inspection? If so, make sure you do not have a primary rule set as Any/Any in the rule set. Gather the traffic rules such as the built in filters for certain applications. As in Google/AWS/Azure services to be trusted. That is if you do not use the web content filter.
