Don’t use with ExpressVPN
I recently posted asking what the best device was for streaming Apollo, because I thought a different device might fix my problems. It turns out my problem was that I was using ExpressVPN.
Every time I tried using the app I would need to clear my cache, reset the app, and sometimes reboot my device. Even after that I would still experience frequent problems while streaming. It turns out Apollo will not work with ExpressVPN. Since switching to NordVPN all problems are fixed and service works very well.
Surf Sharks works great with Apollo
I had same issue with ExpressVPN and couldnt connect to apollo servers. Tried Surfshark and couldnt connect to Apollo using their USA servers. Nord is a bit more expensive but works great with Apollo.
Try get the ethernet kit for fire stick or Purchase the fire cube that has Ethernet port. Zero issues with buffering and I use IPVanish and set it up to connect to the best server for my fire stick and fire cube.
Whats the difference in using a vpn mine works without it
NordVPN is the best, and I don’t know why, but it runs better for me using the Double VPN option.
VPN could help with latency issues, and help avoid any potential throttling of Apollo from your internet provider
Mine too,.it’s just a matter if you don’t care if you are found using channels you don’t pay for. I do use my VPN but id say 70% of the time I do not use it.
I use it for the cough cough Pay per item lol! Channels. That’s when I think they throttle big events
