Discussion: NordVPN 6.37.5 issues; obfuscated server constantly drops connection every couple hours, then auto-connect fails on Wi-Fi after kill switch, then receive notification “unable to auto-connect” /Windows 10
After Kill Switch takes place, auto-connect fails to auto-connect/reconnect to VPN leaving WiFi turned off via Kill Switch.
Configuration:
-Windows 10 Pro
-NordVPN 6.37.5.0 (PAID)
-The following (below) are all turned ON:
-I repeat, all of the following settings are turned ON:
General:
-Launch at Windows startup
-Launch the app minimized
-Show VPN connection status notifications
-CyberSec: block ads and malicious websites
Auto-connect:
-Always when the app launches
-Auto-connect of Wi-Fi : [All networks]; selected
-Choose a VPN protocol and server automatically [I have tried both ON and
-OFF with Obfuscated servers selected:]
Kill Switch:
-Internet Kill Switch
Advanced:
  • Obfuscated servers (OpenVPN (TCP))
    -Help is improve
-A valid subscription
Would be best to contact support directly and report it, especially if it started only after the recent update.
Is Windows Firewall turned on?
Yes, incoming and outbound traffic are allowed for NordVPN on any connection
I’d still try turning it off.
