Deploying Azure VPN client without Intune
Hi everyone, :grin:
I need some help with deploying the Azure VPN Client using MDT. The problem I’m facing is that the installer I have is an online installer, so unable to deploy it with task manager correctly (i didn’t find any offline installer btw)
I actually found a way when deploying an image with a powershell script but of course it is installing the software only and do not integrate my vpn configuration
I tried to install it and capture an image but its not deploying because this is a Microsoft package (lol)
My question is : Is there a way to deploy Azure VPN Client with the configuration file already set when deploying new session. (PLEASE WITHOUT INTUNE :rofl:)
save me please !! :cry:
You can create the VPN connection from PowerShell, too:
Add-VpnConnection -Name “Azure VPN” -Serveraddress “xxxxxxxxx.vpn.azure.com” - tunneltype Ikev2 -AuthenticationMethod MachineCertificate -SplitTunneling $True
Add-VpnConnectionRoute -ConnectionName “Azure VPN” -DestinationPrefix “10.1.0.0/16” -Passthru
Then just use Rasdial “Azure VPN” to connect.
https://learn.microsoft.com/en-us/azure/vpn-gateway/point-to-site-entra-vpn-client-windows
Pretty good idea there, but here i absolutly need to use the software Azure VPN Client because in order to connect to the vpn, you need to authentificate with your 365 account for security. So impossible from the classic Windows VPN configuration. Also tried to find a script that add my xml configuration file directly to Azure VPN Client but didn’t find :confused:
Thanks for your time but its a tutorial to how to add it manually. I use MDT because clients will not have to configure anything so it should be deployed automatically
