Dedicated IP for Apple TV
Now that the Apple TV app is out can someone explain the benefits of a dedicated IP for streaming.
Based in the UK so would love to hear about some examples of what it could used for?
The idea is that it isn’t as obvious to the services you’re using that you’re connecting through a VPN.
Some of them are aware of people using VPNs to bypass geo-restrictions and block IP addresses that look like they’re a VPN endpoint. 5,000 people watching different movies at the same time from one house is a little bit sus :wink::pinching_hand:
That being said, it’s not perfect. It might be flagged for other reasons, eg. it’s a recycled IP address that was used as a multi-user VPN endpoint previously, or it’s in the same subnet as a VPN endpoint etc. it might take a while before the address doesn’t set off their detection system.
If you have multiple devices with different IPs, you can all have them use the same IP, at least a few times a month to get around Netflix and YouTube’s no password sharing rules.
There must be other benefits, I’m just not certain for Apple TV.
Does PIA offer you a new IP if the one they give fails to work with your device?
Not sure if you can renew the address. I think so, but speak to tech support or look at their documentation.
They’re just offering a dedicated IP address, it will do what they say it does: provide you as the user sole access to a single IP address. They can’t guarantee what level of service other organisations will provide to it. Sometimes non-vpn addresses get blacklisted.
Yeah, I’d just only consider it if you would be allowed to change it if you get unlucky and can’t access the service you bought it for. Cycling through the streaming optimized IPs eventually works for me anyways, but I’d consider a dedicated IP if that ever stops working.
