Could someone help me with this? Please
Seem like you need VPN, JP VPN to be specific
You could use SoftEther vpn
use a VPN in the Japan region, the VPN I use is VPN Gate
Maybe the VPN server you chose started with 219.xxx.xxx.xxx, recommend checking step #3 of this VPNGate guide to test if the server is blocked.
Have you success get in with your current vpn setting before ?
Well, if that was why, thank you, I can play it now.
