Connect Spectrum router to VPN?
Can you connect a spectrum router to a VPN? If so, how?
Install the VPN client on your device, open it and connect to a server.
If you mean a network wide VPN installed at the router level, no you can’t do that
I use Asus GT-AX11000 it supports openVPn and wireguard as a server and client and also make a DDNS name for yourself incase your IP address from spectrum changes
actually dealt with this a few days ago, a customer tried his damndest to install a vpn on his spectrum router and eventually his service was shut off and can no longer have spectrum service, guess he was messing with things he knew nothing about and changed/tried to change settings which is not a good idea. just install a vpn on whatever device youre using and youre fine.
there is a LOT more to this story your not telling
thats all i know. we dont know much on the store side other than what were told, or what few notes are on the account.
