Connect Samsung TV with TizenOS to my pivpn with wireguard
I have wireguard through pivpn running at home and i want to connect a Samsung TV from my parents home to my network. I got the .conf file for it but i can’t find wireguard app in the store on the TV.
So my question would be, how can i connect this TV to my home network through pivpn?
Theres no wireguard app for samsung’s tizenos.
Go get a streaming device like ccwgtv, firestick or the cheapest onn 4k android streaming device from walmart. wireguard app is available on those android device.
However, if you want to stick with samsung tv/os, you need a router with wireguard support on your folks house such as like this GL-MT300N-V2 / Mango - GL.iNet to established wireguard connection between your samsung tv and main router from your wg server.
Fyi: dont buy those roku devices too because theres no wireguard app for those ones. If you already bought one, you going to do router mode with wg support to make wireguard connection like youd do with samsung tv above.
My advice if youre not tech guy or your folks… go with the first option. Grab them android streaming device and use the wireguard app.
Fyi2: And yeah dont buy any cheap china made android streaming device available in amazon other the ones i suggested or from well known brand like nvidia. Nvidia got the best one the shield, but thats gonna break a bank for sure.
