Can't connect to primary address (qBittorrent on reverse proxy)
which is weird because if I connect to my local network and then disconnect, it seems to work for like an hour, and then errors out again… and I am not really in a position to come home every hour to connect and disconnect from my home wifi lmao…
I don’t have any advice to fix this issue, but until you get it resolved you can always VPN into your network and connect on local
yes, that is exactly what I’ve been doing
