I tried the VPN trick it didn’t work but the cape is cool and I want it, if anyone of you were able to get the code in India can you tell me how or if you are outside India can you help me get it?
if you are worried about making the account don’t worry I will provide you with an email to make the account.
any help is appreciated.
Join our Discord server IndianGaming
I will tell you. Get turbo VPN lite on mobile and connect to US. Then go to this website . Make sure it’s US and if it shows error because of vpn just change to another US server and retry. Keep trying it will work then use tiktok through that.
The website is some BlueStacks but online thing but only allows trial access to US. Trying to bypass the vpn detection is a pain but what I did was switch to a new server and instantly try again. Any email is fine since it doesn’t ask for code.
Got 4 codes through that so have fun. And goodluck to anyone who finds this actual working method and goes through with it.
Ok, will try it and tell u what happens.
Dude i tried it all on the server, it detected the VPN .
Check DM
