I’ve been trying to find an app that could help me completely block porn
Do it with your router, check how to configure that and that’s harder to uninstall and then block the page of your router config with an app or something else. By the time you unlock everything you’ve alread had enough time to think about what tour doing or just realise what you are about to do
theres allot out there. i dont bother with it though. if im horny enough id just uninstall it.
Bulldog Blocker in the Google Play store blocks 99% of the websites I could think of.
You can also block mixed websites like Twitter or Reddit where porn is easily accessible if you can’t control your urges.
There’s different locks - timers, passcodes, or texting a code to a number. I locked my phone, and set up the lock so the unlock code was sent to someone I trust. I would have to explain to them why I want the unlock code - which would be awkward.
If you have access to your own router, try looking into parental control settings as well.
It’s a paid service but works wonders because it makes it super annoying, time-consuming and straight up hard to just get rid of it. And while you’re trying to get rid of it, you start thinking rationally and catch yourself before you relapse.
As a lot of people here will tell you, no p-n blocker will ever completely prevent you from finding a specific material (because they can be easily turned off on command - and many stock material, that some people find arousing, goes around these limitations). Instead of hoping on some app on computer or phone to do so, prevent yourself from searching p-n.
don’t trust the idea of “YOU MUST CHANGE YOUR MINDSET, YOU MUST RELY ON WILLPOWER”
willpower is finite bro, the key here is to set up your environnement (aka porn blocker)
Blocksite app works well for me. It doesn’t let me access anything adult .
Is there even one that can work in incognito? Most people watch their porn there anyways
you could block the words you’d search for in the blocksite extension and some websites included in other extensions like ‘stayfocusd’ ;
you shall put the chrome extension page & the blocksite page in the stayfocusd block list, after that there’s an option named ‘nucleur option’ in stayfocusd,
if you turn that thing on for however long you’d like to, you will not be able to access nothing unless you remove the extension. it worked well for me it could help .-.
p.s. do know to get the stuff you’d need otherwise you might not be able to access it without removing the extension.
Detoxify
You can really only uninstall it if you know your stuff
Look at openDNS family shield I’ve been using it for years.
Theres an extension for google chrome called block site. You can ban any site from being searched.
Freedom for mobile if on andriod
Cold turkey blocker if on PC
Herr is a private DNS that blocks all that
U can use dns services!
- Cloud fare family dns
2.next dns(make an account and block pornography on settings)
Cold turkey blocker. Actively worth the one off payment, and your fiendish self can’t go about uninstalling it otherwise it soft locks your comp . Have a look into the specs since it’s been a while since I’ve needed it. Stay disciplined young king
Aight thanks I’ll look at it too !
A well disciplined mind
a porn blocker is just like putting a lock on a door and keeping the key, you should probably try to fix your mental health through finding purpose, setting a goal, practicing mindfulness and maybe try to find something you trully enjoy, and i mean you enjoy it in a way where you are happy after you do it, not like porn where you enjoy doing it but then feel like a broken worthless piece of shit after you finish doing it, stay strong.
