I’m asking this because I normally use the free version of ProtonVPN, but they don’t support P2P usage of their vpn networks for free users so I need to find another one. Any free recommendations?
Don’t use free ones. VPNs can be had for a couple bucks a month. Mullvad is highly rated an flat-rate $5/month.
Crypto storm has a free version of their vpn called “cryptofree” with the tradeoff that the server is located somewhere in europe with decimated pings.
As far as advice goes though… free VPNs are unadvisable.
Is it worth it to just not use a VPN altogether if I just want to download 2 games? (About 40 each) My isp is comcast
ipvanish shows pretty good downloading and uploading speed…but in surfshark you wont get any uploading speed
I think Proton has a free option? I never used it thought, I just pay.
i use IPVANISH and usually get my IP’s max speeds for popular torrents. Only have issues with IP alerts rarely and its usually because i start ipvanish AFTER i start qB or forget to turn on kill switch.
is it safe for torrenting?
i am using an older version and dont see any issue its v3.7.5.7
