I have a work network with an OpenVPN server (on a TP Link Omada router). It exports an ovpn file for me:
client
dev tun
proto udp
float
nobind
cipher AES-128-CBC
comp-lzo no
resolv-retry infinite
persist-key
auth-user-pass
explicit-exit-notify
remote vpn.mydomain.com 1194
<ca>
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
</ca>
<cert>
</cert>
<key>
-----BEGIN PRIVATE KEY-----
-----END PRIVATE KEY-----
</key>
I have Android mobile devices running the OpenVPN Connect app, and I have imported the above .ovpn file as a profile in this application. I have it in an “always-on” configuration so that the VPN is always used on public networks (hard requirement).
The problem I’m having is that when the Android devices are on a WiFi network in the office, they cannot access anything. I believe this is due to the egress IP being the same as the VPN IP (loopback). Even if this wasn’t an issue (separate IPs), I’d much prefer to not use the VPN when the device is directly on the work network, as it’s not needed.
So, my question is: is there any way to configure this setup so that the VPN on the Android devices is disabled (or enabled but doesn’t route any traffic through it) when the device is on a specific network? Whether that be a specific WiFi SSID, or subnet, etc.
