Anyone tried VPN/hamachi for reduced ping when playing with peers?
There’s just too much lag sometimes. Wondering if RAFT supports direct p2p gaming via hamachi
Normal Raft is already “direct P2P” so I’m not sure what you intend to gain by adding a VPN layer to the equation.
No, it probably won’t help.
VPN technically increases your ping as you are routing your data traffic via another party first, it just gives the illusion of lower ping due to the VPN reflecting its Ping with the server/host
