Anyone else have problems using surfshark with pornhub?
Hi there /u/worldcitizencane,
Thanks for your submission! You used a flair that corresponds with our rule for contacting support first.
If you have unresolved technical issues or questions, we insist that you contact Surfshark’s customer support before creating a post here. If after troubleshooting with them you still can’t find a solution make a post here and please include their answer. If not, the mods might remove your post when they get to it.
This is our support page. You’ll find both email and live chat there too. It’s 24/7 so enjoy!
You need to specify what you mean by “Problems”, is it not buffering? Is it not detecting your location properly? Kinda hard to troubleshoot an issue without the details.
What i can suggest right now is;
Change protocols >!(I recommend WireGuard or OpenVPN UDP)!<
Change locations
3 Optional: Disable Clean-Web or No-Borders
Clear your browsers cookies & metadata
Try visiting the website again.
Correct, after first video it is not buffering until location is changed, then it can show one video again. Reloading alone does not fix. Tried disabling clean-web, no difference. Don’t know what no-borders is. Disabling the VPN solves the problem, but is not really a solution. I use the SS browser plugin, don’t see any way to change protocols.
Hm, have you tried uninstalling and reinstalling the extension & or clearing your browsers cookies? I highly suggest having the desktop application as you get more options to “tinker” with and more control, you can find the download link here.
