Hey
I use NordVPN and it’s just terrible. It seems it disconnects every few minutes. I locked the VPN app in app switcher to prevent if from going to sleep, disabled battery saving for the app but none of them seems to work.
Do you have this problem?
I use NordVPN on a X3 Pro and I have never had any drop out issues. I am running a custom rom instead of MIUI though.
I use HMA VPN sometimes in my X3 NFC and it works like magic.
Did you updated to the latest MIUI 12.5.1?I have the same problem ever since I did so.
I’m having the same issue with my Poco X3 and Mullvad, really annoying…
Necroing this thread, but same issue with ProtonVPN, did anyone ever find out what’s causing it?
Nord worked perfectly in my previous phone and even now on my laptop.
That aged poorly
Karspersky is not trusted anymore
What do you mean not in USA? That place was the first one that came into my mind…
