My ExpressVPN sub expired so I thought it would be a great time to look around at other vpn options. On that road I came across PiHole and set it up on my Pi 0w, it’s been great so far but I still needed a vpn. I came across OpenVPN, 2 free connections?? Wow can’t pass that up, so I set it all up using AWS and now I’m set with a vpn. Only now the ads are back in full force, the preferred ipv4 dns is still set to my PiHole dns on my devices though.
Long story short, is there any way to have the same level of ad blocking with just OpenVPN or do I have to sacrifice one of my two connections by installing OpenVPN on my Pi in conjunction with PiHole?
With Cloudconnexa you get 3 free connections to a PRIVATE network. It does not by default give you a gateway to the internet nor does it do adblocking. You can add that by connecting your own DNS server like pihole that does adblocking and pushing that to clients. You can also add an internet gateway to redirect internet traffic through that gateway. Cloudconnexa does have DNS filtering capability already built in by default that you could look into, it has various categories it can block like malware, porn, etc. This might do what you want.
Then there’s access server which you get 2 free connections with and also can serve as an internet gateway, and is self hosted. If you install or already have something like pihole adblocking and configure access server to push that DNS server to VPN clients then you have achieved your goal.
You can also run OpenVPN community server and pihole and configure it to do the same as access server but it’s a bit more work for you to figure out how to do that.
I tried to push my pi dns server to OpenVPN but because it’s a 10.0.0.x address it’s internal to my home network and not the virtual network. I enabled all the blocking features in shield including adware but I was getting every add on every website. There’s also a 1k domain limit for their blocklist, and even ad.doubleclick.net was not blocking any Google ads. I’m going to try setting up a new server on AWS, install OpenVPN and then setup PiHole on that server. Hopefully that works cause if not I might have to look into another vpn service.
I’m not paying for anything, there’s 2 free connections for CloudConnexa which is part of OpenVPN, If I want more connections I have to pay. I’m using it for my computer and my iPhone but if I put OpenVPN on my Raspberry Pi that’s 3 connections, so I’d have to sacrifice using OpenVPN on one of my devices if I want to have adblocking and a vpn.
The issue is not whether it is possible. It’s simply a lack of understanding. Your goal should be to run a DNS server that blocks ads like pihole, and ensuring that OpenVPN is configured to tell VPN clients to use that, and that they are actually using it.
In any case the 2 connections you get are only to cloudconnexa. OpenVPN itself is a free protocol with support on many devices and is of course free. So if you are technically inclined you can do what I do and setup a OpenVPN server on your home network and have all your devices connect to that. You can do your add blocking there. Then you could use one of your free connexa to get to the internet if you want around your ISP.
Uuuh, why not just run PiVPN script or any other road warrior script in AWS or the Pi directly? That way you get as much connections as your server can support.
It’s apparently 3 devices for cloudconnexa and 2 connections per user (still a total of 3), I just created a new user and added a test device, so I just have to configure the user and device and it should work for my use case. What you described sounds interesting though, is that only for your home network though or can you still use your vpn setup on cellular for example?
Cause I literally just got into this today, first time I’ve ever done anything like this or used AWS. So I’m just learning as I go, any advice it helpful though
Well idk what to tell ya, you’d see the same thing I see if you went to Cloud VPN Services | CloudConnexa | OpenVPN logged out. “Get Started Today and Get 3 Free Connections” and in my dashboard it says 2/3 connections used.
Yeah, even a basic Lightsail on AWS should be powerful enough for both, alternatively check Vultr, Digital Ocean, or Linode. If you’re feeling lucky try Oracle Cloud to have them for free.
